Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > ArtCam Pro
ArtCam Pro Discuss ArtCam Pro software here.
  #13   Ban this user!
Old 08-09-2009, 02:02 PM
Vegabond's Avatar
Vegabond is on a distinguished road
Maby it is the size of the letter`s?
When i use big letters (25mm), i cant carve with only one line, but is the letter`s smaller (10mm), i can.
Im a little confused.... :P
Thanx for the help.
Robert.
ID:	86079   Click image for larger version
ID:	86080   Click image for larger version
ID:	86081   Click image for larger version
My second homebuilt cnc machine cnczone.com/forums/norwegian_club_house/123977-ombygget_cnc_-_gecko_540_a.html
  #14   Ban this user!
Old 08-09-2009, 02:09 PM
jalessi's Avatar
jalessi is on a distinguished road
What do you mean by "you cant carve" ?
Please provide more details.
Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
  #15   Ban this user!
Old 08-09-2009, 02:50 PM
Vegabond's Avatar
Ok, sorry, i mean i can`t carve with only the senterline, it came many lines. And the cnc is using much more time to carve many lines in one letter.
I figured out that when i try to make smaller letter`s, it came just a senter line, but when i write bigger letter`s, it came many lines...
Understand?
Thanx. Robert.
  #16   Ban this user!
Old 08-09-2009, 03:18 PM
jalessi's Avatar
Post
If Artcam needs to make multiple passes to cut out a font it is not a true single line font.
If the cutter width is not as wide as the toolpath it needs to make multiple passes.
You need to use a single line font or a larger diameter cutter if you want to save time.
  #17   Ban this user!
Old 08-09-2009, 03:19 PM
Vegabond's Avatar
Yeah, i see that now...
Can i just carve the outside of the letter`s ? do i have to use the 2d profiling then ?
Robert.
  #18   Ban this user!
Old 08-09-2009, 03:20 PM
jalessi's Avatar
Look at these videos
http://www.artcam.com/videos/2DCNC.htm
  #19   Ban this user!
Old 08-09-2009, 03:23 PM
jalessi's Avatar
  #20   Ban this user!
Old 08-09-2009, 03:24 PM
Vegabond's Avatar
Thanx, i have been to their side, but i haven`t seen theese video.
Many thanx, i came back with more questions
Nice to have forum....
Robert.
  #21   Ban this user!
Old 08-13-2009, 03:52 PM
Vegabond's Avatar
Hello again!
What filetype do i need to save as, when i want to open it in artcam 2008?
I use AutoCAD 2009.
Robert.
  #22   Ban this user!
Old 08-13-2009, 06:40 PM
keebler303 is on a distinguished road
I always import .dxf files into artcam.
Artcam seems bad about creating errors with little tiny gaps and things that you don't see, can be a real pain to find them all sometimes.
You set a max depth on your V carving, if the width of the v cutter does not cut the whole width of the letter while staying above the "maximum depth" then it will take multiple passes. If you want single pass letters you need to either increase themaximum depth setting or use a cutter with a larger angle so it makes a wider path.
Matt
  #23   Ban this user!
Old 08-14-2009, 08:47 AM
Vegabond's Avatar
Ok. Many thanx!
The DXF file, what type DXF do you use? "2000/LT2000" or "2004/LT2004" or something else?
Robert.
  #24   Ban this user!
Old 08-15-2009, 12:54 PM
I don't use autocad, its just dxf for me. It shouldn't make a difference to artcam, try both and see.
Matt
CncBrain SDK - VB.NET 2008 Switcher CncBrain 3 12-10-2011 11:20 PM
Artcam 2008 -Noen som bruker det? Vegabond Norwegian Club House 11 04-01-2010 01:09 PM
CWX SP2.1 for 2008 pixburghenat CamWorks 6 05-16-2008 03:39 PM
Just IN- ArtCAM Insignia 2008 now available Beckyf Product Announcements & Manufacturer News 0 04-02-2008 09:12 AM
Learning SW 2008 SPEEDRE Solidworks 6 01-29-2008 12:30 PM
