| ArtCam Pro Discuss ArtCam Pro software here. |
HI, When importing a 3D model in Artcam pro I don't get the vector in the 2D view, so I can only generate the gcode for machining the entire "material", not just the vector of the 3d guitar top I want to machine...how can I solve that? Thank you and don't mind my english, I'm italian Last edited by rockappalla; 03-24-2009 at 10:33 AM. |
| Using the "relief preview" will give you a shape to trace. You may even be able to use the "Bit map to vector" function by messing with the colors. Don't have time at the moment. If it works I'll post it later. Hope this helps. |
| Try this instead. Import your STL file. Then save the .stl relief as a .rlf file. "Reset" your relief layer. After that "paste" the saved .rlf file. You'll have a vector outline of the profile. I would take a minute to smooth out the nodes. Pasted .rlf vectors are pretty jagged. Good luck |
| Thank you todd, I will try that later... This is the way I'd like to machine it... just the top, not the whole piece of wood...probably the machining time will be the half... |
| Importing from Rhino to Mach | gregrnel | Mach Mill | 20 | 03-04-2009 11:41 PM |
| Need Help!- importing control point curves from rhino | EvanB | BobCad-Cam | 1 | 06-24-2008 07:07 AM |
| Importing dwg.files | wsteve | Rhino 3D | 2 | 05-09-2007 02:51 AM |
| importing Mastercam art files in Rhino | sdantonio | Mastercam | 4 | 04-02-2007 09:07 AM |
| Importing from Rhino to Starcam | routerman | StarCam CNC | 1 | 03-30-2007 11:09 PM |
