Results 1 to 11 of 11
Thread: Difference in Artcam 8.0 and 9.0
    Apr 2007
    What are the differences in Artcam 8.0 and Artcam 9.0 . I can get Artcam 8.0 at a fair price. Just wondering what the differences are.
    Registered todd71's Avatar
    Nov 2006
    U.S.A.
    Mainly just the layout of the buttons. Which I can't say was an improvment. And it can import .pdf files. Also Ogee and Round over tooling is in the tool data base. If the price is right grab the version 8. Your not missing much.
    Mar 2007
    I have been using Version 9 for a while now and I can say there is great change.
    First of all, there is a future that helps you diffeent layers of reliefs on the same project. So if you if you need to do couple or more reliefs and than save them and put them on top of each other, you don't need to open several projects, you can do it on one. At first this seemed like useless for the projects that I do, but the more I use it, the more I understand the importance of it.
    Also, on version 9, there is a rope creator tool that I use a lot, which makes things easier.
    What do you work on ?
    If I knew what you were doing, maybe I can tell you if version 9 is too much for you but I need to know what you are working on.
    you can always email me at urkun.kerim@gmail.com
    kerim
    Apr 2007
    I just picked up a Gerber demension 200. It came with Omega art path which is only 2D. Looking to get software that will do 3D. Either artcam or Enroute3. As for what I am making Just wood signs. I do not do it commercially just play with it. Big boy big toys. Thanks
    Nov 2006
    U.S.A.
    Here's the rope creator for version 8. I wasn't all that impressed with it. There again I never needed to put a rope boarder on anything.
    Attached Files Attached Files
    Apr 2007
    Thanks Todd
    Nov 2006
    U.S.A.
    No problem. I must admit kerimurkun has a valid point with the relief layer feature on version 9. Thats a real time saver. And I can't say ArtCAM is better than enroute3. But it is kick ass. I find most the jobs coming to my shop require so much less than what ArtCAM can deliver. A cheaper package will still make you money.
    Good luck,
    Todd
    www.innovative-accents.com
    Registered Sean P's Avatar
    Aug 2005
    Here is a more comprehensive list for your review of the differences between V8 & V9;
    General Tools;
    New Layers Manager
    New Model Resolution
    New Reference Help System
    Enhanced Assistant
    Modified Top Toolbar
    Modified Main Menu Bar
    Improved Toolbars
    Enhanced Vector Sheets
    New PDF Import
    Vector & Bitmap Tools;
    Enhanced Use of Selected Vector Artwork
    Copy Bitmap Section
    3D Modelling Tools
    New Relief Clipart Library
    Modified Relief Loading
    Enhanced Relief Export
    Front & Back Reliefs
    Machining;
    Enhanced Tool Database
    Miscellaneous;
    New ArtCAM Advantage Website
    Apr 2006
    na
    rope creator
    Quote Originally Posted by todd71 View Post
    how do you install this just copy into toolbox folder in artcam?
    will this ver work in 2008?
    Nov 2006
    U.S.A.
    Quote Originally Posted by eloid View Post
    If I remember right.
    Extract zipped files> My computer> Local Disk (C> Program files> ArtCAM> Paste in "Tool Box"
    You should have "Face Wizard" in the toolbox already. Just add there.
    It should work with 2008. Don't see why not. But I really don't know.
    Good luck
    Web-site: http://www.innovative-accents.com/
    Blog: http://blue-collar-nobody.blogspot.com/
    Jan 2010
    Artcam Toolbox
    hi !
    .... thanks to all of you for those useful posts....... I'm new with Artcam, where can I download some more add ins (those in the toolbox)..... I've tryied with success the rope creator (thanks to todd71), I know there is more but I can't find them......... and I know it could be useful for other users
    thank you in advance
    regards,
    1. ArtCam Pro
      By CNCadmin in forum ArtCam Pro
      Last Post: 07-12-2012, 04:31 PM
    2. What's the difference?
      By saturnnights in forum Knee Vertical Mills
      Last Post: 05-04-2006, 11:31 AM
    3. What is the difference?
      By Hack in forum General CNC (Mill and Lathe) Control Software (NC)
      Last Post: 10-09-2005, 10:46 AM
    4. What's the difference?
      By Hack in forum General Metal Working Machines
      Last Post: 09-05-2005, 08:35 PM
