Results 1 to 3 of 3
Thread: Questions -saving files in sequence/creating new models
    Feb 2007
    Hi all, new to ARTCAM...hopiong you can help me. Main questions I have are:
    When creating a new model and loading the relief from previous file, it reads "ARTCAM PRO - (untitled) - [2DView:0]. The only vectors that transfer are border vectors around new blank size...why?
    2.) When creating a new model, I can transfer a previous 2D ARTCAM drawing, but, if i want to enlarge or reduce the overall size without changing proportions, I can't - why not?
    thanks so much for any input!
    Registered todd71's Avatar
    Nov 2006
    U.S.A.
    Quote Originally Posted by When creating a new model and loading the relief from previous file, it reads "ARTCAM PRO - (untitled) - [2DView:0
    I think thats because a relief (.rlf) is a gray scale image. Which uses varying shades of color to define the hight of the relief. You can view it as a bitmap image after you paste it to the file. The vector boarder is mainly a guide for placement while pasting and for cutting the profile.
    "When creating a new model, I can transfer a previous 2D ARTCAM drawing, but, if i want to enlarge or reduce the overall size without changing proportions, I can't - why not?"
    I'm kind of confussed on this one. Seems to me the proportions would have to change. Your 2D vector image is getting bigger or smaller depending. Maybe I'm not reading your question right
    Attached Thumbnails Attached Thumbnails Questions -saving files in sequence/creating new models-bit_map_layer.jpg
    Feb 2007
    Thanks so much Todd!
  1. Creating surfaces from .iges files
    By homebrewCNC in forum Mastercam
    Last Post: 09-10-2006, 12:27 PM
  2. Creating .dxf files
    By lal19541 in forum General CAM Discussion
    Last Post: 08-31-2006, 02:40 AM
  3. cut sequence
    By camtd in forum Surfcam
    Last Post: 06-13-2006, 12:26 PM
  4. Sequence #'s
    By Mountainwildman in forum Post Processors for MC
    Last Post: 04-02-2006, 12:25 PM
  5. Power up sequence
    By Konstantin in forum General Electronics Discussion
    Last Post: 10-05-2004, 06:05 PM
