Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > ArtCam Pro
ArtCam Pro Discuss ArtCam Pro software here.
Old 02-03-2007, 04:54 PM
keebler303 is on a distinguished road
Engrave on a curved surface
Can Artcam pro do v carving on a curved piece? I want to engrave some chair backs and i need to figure out if artcam can do it from a dxf and then specify the radius of curvature.
Matt
Old 02-05-2007, 10:44 PM
todd71's Avatar
todd71 is on a distinguished road
I dont think it can. V carving is a 2D toolpath. You could make the curve with a 2 rail sweep and apply the feature using the triangle form subtracted into the curve. Then machine the whole thing, or just the feature if the curve is already done, as a relief.
Todd
Name:	sample curve 700X584.jpg‎
ID:	31088   Click image for larger version
Name:	sample curve 2 700X584.jpg‎
Old 02-06-2007, 06:33 PM
Stepper Monkey is on a distinguished road
Artcam does indeed have engraving features, with several ways to do this sort of thing. I have used them quite a bit for v-bit carving in the past, but seldom on irregularly curved objects.
Getting a toolpath generated to do this is easy, getting the curve you program in to exactly match the curve of your actual workpiece is nigh impossible. With a v-bit even a few thousandths change in depth will obviously change the width of the cut as well, so even very minor changes in depth are noticable.
I don't work with routers at all, but perhaps there is some kind of feedback sensor for controlling depth stop, or even a weighted/springloaded telescoping toolholder to keep even pressure - and therefore depth of cuts - over uneven surfaces? How is this problem normally solved? I have always wondered!
Old 02-08-2007, 06:52 PM
thanks guys i think i have gotten what i want with feature machining and just using a v bit, even though it isn't a v carving toolpath.
Matt
Old 02-12-2007, 02:07 AM
You can also try using the "machine along vector" toolpathing tool. It is a very simple way to do the same thing. It just follows the vector lines - like a pen plotter path - all you set is the depth.
Old 08-20-2007, 05:02 AM
MRicht is on a distinguished road
spring loaded engraving
Check this out:
http://www.2linc.com/spring_loaded_engraving_tool.htm
Old 09-03-2009, 07:03 PM
suwat is on a distinguished road
"machine along vector" can not ... any new update ? to cut along vector on curve surface
Rhino engrave text on curved surface replicapro Rhino 3D 10 03-11-2008 12:32 PM
creating a straight c-bore on a curved surface bennett71 Solidworks 12 02-14-2007 12:58 AM
JPEG/DXF file to a curved surface? Dougotio Rhino 3D 0 01-26-2006 12:27 PM
text/dingbat to curved surface? Dougotio Rhino 3D 2 01-18-2006 06:58 PM
How do I engrave numbers... slp_prlzys DIY-CNC Router Table Machines 7 10-15-2004 02:35 PM
