Results 1 to 5 of 5
Thread: artcam and mach2
    flipper
    Guest
    artcam and mach2
    Hello everybody,
    How does a postprocessor work in artcam? There is a post processor in artcam for .NC, but how do i use this.
    Thnx.
    Jan 2007
    Drop it in the folder with the other ArtCam post-processor files (I think its named PostP), restart Artcam, and the new options should then be selectable - when you go to save your next toolpath it should be on the list. I believe there are actually two post processors for Mach - inch and metric.
    How the g-code functions then with your controller and hardware setup, who can say, but that is how to get the processor installed and the g-code generated.
    I use Mach3 myself, but do not use the Mach post-processor - Mach nicely eats one of my other machines formats as well, and so I only use one format for portabilities sake between them.
    Registered TechGraphix's Avatar
    Jun 2006
    Netherlands
    Quote Originally Posted by flipper View Post
    Hello everybody,
    Thnx.
    Just look in the postp files how they are build up.. It's plain text..
    I wrote several postprocessors for ArtCam for different machines and interfacing programs like WinNC, EaziCNc.
    You only have to know what your CNC talks..
    Kees
    Aug 2005
    UK
    I have found a post from you 12 months ago answering someone about artcam and a postprocessor. I have been trying to get hold of a post processor for feature cam which will intergrate into eazicnc?
    Jun 2006
    Netherlands
    Send me your mailaddress and i will send you my postprocessor.
    Place it in the artcam/postp folder and you will have your G-Codes generated for EaziCNC
    K36914@hotmail.com
    Kees
  • Posting Permissions
