Results 1 to 6 of 6
Thread: ArtCam pro tutorials
    Mar 2010
    America
    Hello All,
    I downloaded these tutorials from here.
    http://digfablab.wikispaces.com/ArtCam+Pro+Tutorials
    ArtCam pro tutorials.pdf
    NewTeddy.art
    The very first tutorial "new teddy" following the tutorial step by step with the teddys ears my results are different than the results of tutorial. Could this be a error in the tutorial or am I totally missing something. Hoping some1 will give a try and see there results.
    Dan
    Dec 2011
    Dan
    That's an old tutorial but it is correct. You don't say how your results were different but my guess is you failed to do a merge high with the shape editor for the parts after you added the main body.
    Gary
    Beckwith Decor Products
    ArtCam Reseller/Trainer, Custom tooling & Onsrud Dealer
    Mar 2010
    America
    Thanks for your reply Gary,
    My trouble is with the ears of the teddy, I get the same results as the tutorial with everything else.
    This is the results shown with tutorial.
    This is the results I get.
    No matter what I tried I can't achieve the same results shown by tutorial pic.
    Dan
    Dec 2011
    Dan,
    I just looked at the instructions in the link you supplied, they are incorrect and do not match the instructions with our book of tutorials, which I previously referred too.
    to correct the model do the following.
    Creating the ears
    1.Select outer vector (for both ears, should be grouped)
    2.Hold shift key and select inner vector of the ears (all 4 vectors will be selected)
    3. F12 to bring up shape editor - select dome shape with no limit, angle 45° and start height of 0.5. Select Add
    (this will create the outer ring of the ears)
    4. Deselect vectors and sector the inner vector to both ears
    5. F12 for shape editor - select flat plane start height of 0.5 and press Merge High.
    This will put you back on track
    edit: one more thing the original model is very low in resolution so you might up the res before building the model for a better finish
    Gary
    Mar 2010
    America
    Thanks Gary, I thought there might be a mistake with the tutorial but what really annoyed me was that I was able to figure it out . It was the flat plane I was overlooking.
    Thanks Again,
    Dan
    Dec 2011
    No problem Dan
    Gary
    1. CNC Tutorials
      By Smooth90 in forum Videos
      Last Post: 11-13-2012, 02:43 AM
    2. Need Help!- ArtCam/ Artcam Express IMPORT (STL file)
      By milepost131 in forum ArtCam Pro
      Last Post: 01-19-2012, 10:36 PM
    3. Need Help!- artcam 2010 examples to artcam 2008
      By mishu28nmv in forum ArtCam Pro
      Last Post: 06-15-2011, 01:27 PM
    4. tutorials
      By elc in forum SprutCAM
      Last Post: 05-19-2010, 02:41 PM
    5. Newbie- Need Tutorials
      By White Rabbit in forum Cimatron
      Last Post: 03-13-2009, 02:34 AM
