Results 1 to 10 of 10
Thread: ArtCam with 2 routers?
    Gold Member walter's Avatar
    May 2003
    Question ArtCam with 2 routers?
    I have 2 questions.
    Can I run ArtCam on my PC and then send the code via ethernet to the second computer in my shop downstairs?
    How can I use ArtCam with 2 routers simultaneously? Do I need special software or special hardware?
    Thank You
    Registered abasir's Avatar
    Apr 2003
    Malaysia
    Q1:
    IIRC, ArtCam does not control your routers; it just creates the G-Code files. Send the G-code file to your other computer via ethernet and run your router controller software there.
    Q2:
    What interface/type is your router (serial/parallel, stepper/servo, etc)?
    Is it one router machine with two router heads? ;0
    Stupid questions make me smarter...
    See how smart I've become at www.9w2bsr.com ;-P
    May 2003
    Question
    First router will be 2 head (slave) servo system built around FlashCut CNC controller connected via serial port. I would consider second machine, maybe servo, maybe stepper- probably ready built by some reputable company.... Just wondering if productivity will double with 2 machines or this may be complicated....
    Apr 2003
    Duluth, GA (Metro Atlanta)
    Hi Chip!
    Production definitively will be higher with 2 machines. You can produce with one copy of ArtCAM jobs to run in several CNC's. You always produce the toolpaths in ArtCAM the same way. You may have to select a different machine when saving the toolpath file. There is not difficulty at all.
    Let me know the specs of the second machine.
    Best regards,
    Ernie
    May 2003
    Thumbs up
    sounds good. thank you
    Apr 2003
    You are wellcome
    Ernie
    www.cadcamforjewelry.com
    Jul 2003
    FT.LAUDERDALE,FL
    hello,
    i'm looking to up my skills in 3d carving in wood and inlays.
    i'm looking for training videos or cd's in artcam pro. i use enroute3 now not to happy with it.
    thank you,
    brian
    briana32@bellsouth.net
    May 2003
    Question
    whats wrong with Enroute3 ? I was just thinking about this software as an alternative to Artcam.....
    Aug 2003
    Loveland, CO
    Originally posted by MTNBIKER
    hello,
    thank you,
    brian
    VS3D excels in 3D carving and is very competitively priced with features comparable to ArtCam (and has many features ArtCam doesn't have). You can download VS3D and run in demo mode. And you can get a free 30-day evaluation key to try designing and cutting parts with VS3D before you buy. VS3D has an on-line tutorial that you can follow along at: http://www.designscomputed.com/vs3d/...our/index.html
    VS3D's home page is at:
    Daniel Carr - President,
    Designs Computed, LLC
    Jun 2004
    United Kingdom
    Just create multiple toolpaths, merge them if required, and post process them onto your disk.
    Then copy to each network PC and send to the CNC machines, in parallel if required. I recommend one PC per CNC to avoid timing problems with serial/parallel/usb ports.
    Paul (ArtCAM Insignia Developer!)
    BTW We will be releasing Insiginia-E soon at an entry level price for 2D engraving and machining, including 10 fonts for V-bit carving.
    1. ArtCAM substitute?
      By Arnie in forum Rhino 3D
      Last Post: 09-15-2010, 09:31 AM
    2. Plasma G-code with Artcam?
      By coherent in forum ArtCam Pro
      Last Post: 11-22-2006, 08:31 PM
    3. ArtCam Feature????
      By Donald in forum ArtCam Pro
      Last Post: 05-09-2005, 10:48 AM
    4. Software that is compareablr to ArtCAM
      By matt in forum ArtCam Pro
      Last Post: 06-06-2004, 10:04 PM
    5. Cantilevered routers and other ideas...
      By chuckknigh in forum DIY CNC Router Table Machines
      Last Post: 05-24-2003, 06:41 AM
