Looks like they don't show if they are .BMP so here's .jpg's
Hey Guys,
I've held off as long as I can on posting this question but after spending many, many hours trying to get it right I have to now ask for some guidance and advice.
My question is: What are the best steps to take to make a complete relief of the medallion below ?
One of the things I've done after drawing it in Corel was to save it as a .BMP and drag and drop it into ArtCam Pro then proceed to color fill the individual parts. The main problem I have is that I want all the lines in the eagle to be V-cut and all the other lines I want to add height to them. The problem there is that when I dbl. click on the black lines and add height, it of course adds height to the lines in the eagle which is the exact opposite of what I need.
How would you guys go about this ?
Thanks for any help,
Steve
The one pictured that I'm doing is 14" x 14" and I'm trying to achieve what you see in the color pic of the wood one.
BTW: Why the heck don't my pics show up on the Zone tonight and most other times they do ???
Have you see the tutorial video for the plaque with the Aston Martin? I think that looks a lot like what you want to do. You need a very clean image to work with.
Hi Jay,
I'll check it out.
My drawing is very clean I think and I can isolate and color fill all parts, it just gets a little confusing on achieving the look I need. ANY advice is much appreciated !
Thanks,
Steve
[nomedia="http://www.youtube.com/watch?v=lszUTq06g40"]YouTube- Creating a 2D sign in ArtCAM Insignia[/nomedia] is close
http://www.scribd.com/doc/16371530/A...-Pro-Tutorials has the Aston martin tutorial ... thought it was a video but I guess not.
If you convert the images to vectors, you can create new vector layers. Then move whichever vectors you need to individual layers. I recommend giving each layer a different color.
Thanks for the help! I finally had time to get back to work on this and have made some progress. I need some more help though, in the pics below you can see the vectors and then as machined simulation. I'm very happy with most of it however I can't figure out how to get the feather lines to machine and show better as well as the lines in the plaque below the eagle.
Is there a way to thicken the vector lines at this point within Artcam or what should I do ? I have one more minor question on this model but I'll take it one step at a time.
Thanks,
SS
Look at the offset tool. Pick the vector you want to offset (there are usually 3 options, inside, outside and both). If you do "both" you'll want the vector to be the centerline. Hope that helps.
Jay C, That worked very good, thanks, that definitely helped. I'm used to working with offsets in other SW but hadn't thought about it in ArtCam. I selected "both sides" and "delete original vectors" and now the grooves in the wings and the plaque show up better.
Only problem is when I copy vectors into bitmap, they stair step a lot. Any way to smooth them out ? I can actually live with it as is now but if it can be done better I'd like to try.
Thanks again,
SS
What end mill bit are you simulating with? If it's a 3D relief, it needs to be a ballnose finish path after a roughing pass with a square end mill. Also, you should change the angle of the finish pass with and rough pass. And last but not least, it's usually a good idea to leave some allowance on the rough pass. This gives the finish path the ability to remove the coarser roughing path tool marks.
Well I actually haven't done the toolpaths exactly as I want to for machining yet, I have only selected a 50 deg. V bit for simulation in one pass. Right now I just wanted to see if I had the design good for machining. I did it using "3D Machine relief" in the toolpaths tab.
I do plan to do a roughing pass with a 1/4" EM and leaving some allowance then a finish pass with the V bit. That's my plan, please advise if it's wrong. I did not know that I needed to make the finish pass at a different angle than the roughing pass though, thanks for that advice too.
What do you think about the stair stepping problem ?
Here's a pic of just the "Front Relief" view to show more of the design without machining marks...
It's due to he bit you have chosen. Try a ball end mill and see the difference.
