Yes, I milled them using Eagle and PCB-Gcode. The circuits are simple series/parallel circuits. If you want some of the eagle files I'd be happy to post them. I settled on 8 inches for the width of my signs. Did you see the wooden boxes?
Well at least you found the problem, I just posted on that. I also have watched some of your vids on YouTube, very good, and your lighted acrylic projects turned out great ! I'm very impressed that you go to the extra effort of providing ALL the specs such as material, endmills used, DOC, feed rates, ETC. That is a real help and very few do that and it's important.
I've done one small lighted acrylic on my X2 and I'm real happy with how that came out, I used a small blue LED strip that came out of a dead XM receiver. Can you tell me what LED strips you used or did you make them ?
Great work and I look forward to seeing more, I'll post a vid of my machine making the plaque in this thread.
BTW: re: your LED light PCB's, I use Eagle and PCB-Gcode too.
This is my favorite sign and the last one I made.
I like it a lot too. I have spent the last hour or so looking for a drawing or photo of that dragon. It looks very familiar to me but all the ones I found are similar but not the same one. Can you provide a link to the image of the dragon? Did you carve it as a lithophane or a relief? Post 25 refers to U tube videos with cutting information, can you provide a link to those also? I looked through your posts here and found your blog page and didn't see any links. Sorry if I missed them.
I do really like the way that dragon looks.
The dragon I got from cnc4free.org homepage. Danny was nice enough to repost it for me to use. There is a threads called share your 3d part or art he regularly posts to. I cut it as a relief on the back so the front is smooth.
My youtubes are here
-Jay
[QUOTE=Jay C;858591]The dragon I got from cnc4free.org homepage. Danny was nice enough to repost it for me to use. There is a threads called share your 3d part or art he regularly posts to. I cut it as a relief on the back so the front is smooth.
Thanks for the info. I knew I had seen that dragon somewhere. It is no longer on the cnc4free site, I had looked there, but I found a picture in the thread on the zone. I will see what I can do with it.
You have some neat and interesting projects. I am going to check out your circuit boards for the led edge lighting.
Each circuit depends on the number of LEDs (I use 8 mostly) the forward voltage (3.2 for White, 2.97 for Blue, and 1.4 for Red typically). Like I said, I use the simple series parallel circuit designer.I missed that. Where's that at ?
If you use Eagle Lite then for 8" you have to break it into two circuit boards.
-Jay
jay c,
now your dragon you used a 3d bit and just carved the back side of it?
thanks kevin
There are three tool paths:
1. A cut out tool path with a .125" (1/8") flat end mill and a finishing pass at full depth
2. Relief toolpath with a .125" (1/8") flat end mill roughing with an offset of .008"
3. .0625" (1/16") ball end mill finish with 0 off set and with raster angle set perpendicular to the roughing pass.
I used 25-33ipm due to limitations of my machine. My speed was 11KRPM at a depth of cut no bigger than 1/D of the tool used per pass on the first two paths. On the third, I let it cut full depth.
Jay
