Results 1 to 11 of 11
Thread: making good negative picture
    Aug 2009
    USA Michigan
    can someone tell me how i can make a good negative , so i can make a good bitmaps, trying make a bear sleeping on a tree branch. (I have artcam and photoshop, my negative just don't look good)
    thank you
    Apr 2010
    Russia
    Can you show an example of model which you would like to make.
    Aug 2009
    USA Michigan
    i don't know how to put picture on hear. if you have a picture to show me that would help, just need to know what program and how you do it if there is a trick to it
    thank you
    Apr 2010
    Russia
    Do you read tutorial "ArtCAM sculpting masterclass"(making face from photo)?
    I think that it's very difficult to make good model using only Photoshop. I use 3d software to make model and than import 3d model into ArtCAM.Result you can see here.
    Aug 2009
    USA Michigan
    what 3d software do you use? is the pitchure did you just bitmap it and then clean it up a little or is there a lot more to it
    Apr 2010
    Russia
    Models which you've seen are modelled in 3ds max and than imported into Artcam in stl format. I can send you some of these reliefs if you give your e-mail adress. You can use any 3d software including free ( Blender)
    Aug 2009
    USA Michigan
    if you don't mind sending them. electric2u@gmail.com
    Apr 2010
    Russia
    Check your mailbox
    Aug 2009
    USA Michigan
    do you have more of those PDF i can look at
    Apr 2010
    Russia
    No, only this tutorial.
    Registered todd71's Avatar
    Nov 2006
    U.S.A.
    For that "pheasant" I just used "picture it! 9" Which is vary basic. I wouldn't even recommend it considering Corel or Adobe are so much better. Checkout "Blender" http://www.blender.org/ An "alpha-map" works great for converting to relief. There's a pretty steep learning curve with it. But the results can't be denied. Doesn't really help for converting a picture. But as far as modeling its great. Good luck.
    Web-site: http://www.innovative-accents.com/
    Blog: http://blue-collar-nobody.blogspot.com/
    1. Build Thread- Bobcad making good.
      By highspeedmazak in forum BobCad-Cam
      Last Post: 07-29-2008, 08:51 PM
    2. making a 3D model from a picture
      By radavis in forum Solidworks
      Last Post: 12-24-2007, 09:08 AM
    3. Making a positive mold from a negative mold - how?
      By SRT Mike in forum Moldmaking
      Last Post: 03-29-2007, 05:30 PM
    4. ? Good wood for larger sign making
      By mcmmach in forum WoodWorking
      Last Post: 02-25-2006, 11:05 AM
    5. Anyone Know a know of a good book for mill, tool making?
      By sendkeys in forum General Metalwork Discussion
      Last Post: 11-01-2004, 10:56 PM
