Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > ArtCam Pro
ArtCam Pro Discuss ArtCam Pro software here.
Old 05-03-2005, 08:35 PM
Donald is on a distinguished road
ArtCam Feature????
I've never used ArtCam Pro, but a freind of mine purchased it for his shop. He wasn't able to answer my question so I'll ask the guru's of this site.
If I use ArtCam to create a mold, and i tell it the dimensions of my block of material. And after I create the file i want to machine into a mold. Can ArtCam tell me how much void or material i've removed. Allowing me know exactly how much material a vender will use to fill this mold?
I've worked all the bugs out of this adventure except the exact amount of material of the void. I guess i could machine one, and then pour water into the mold and calculate that. But I thought that Artcam might have that feature or information.
And if ArtCam doesn't have this feature to figure this out. Is there any other software out that that does?
Don
Old 05-03-2005, 08:50 PM
justin is on a distinguished road
There is a volume function. I have seen it used in the training video. I think it is under the "relief" tab. I can confirm that later.
Old 05-03-2005, 09:03 PM
Thanks justin,
I'll have to head down the road afterwork tomorrow and check that out
Don
Old 05-03-2005, 09:36 PM
I wonder if thats the amount removed or the amount that is left after machined?
Don
Old 05-04-2005, 06:07 AM
if I understand it right, you can select the relief that you wish to know the volume of. There is also a lot of help with that stuff on the ARTCAM forum site.
Old 05-08-2005, 10:29 PM
dcarr is on a distinguished road
Volume calculations in VS3D
VS3D can report the volume of a sculpted relief surface (mold).
And it can do it from the original surface, or after the machining passes. So you can see how much material the mold holds, as well as how much material remains to be cut. The "Help / Surface Statistics..." menu in VS3D is where the volume report can be generated.
Daniel Carr - President,
Designs Computed, LLC
Old 05-08-2005, 11:56 PM
joecnc2006's Avatar
www.joescnc.com
joecnc2006 is on a distinguished road
i have seen it in a g-code from someone do a circle by toolpath on inside it make a long g-code, instead of a short line telling it from start to curve I and then end.
Instead it moved x and y all around the curve.
Old 05-09-2005, 07:15 AM
ger21's Avatar
It probably has to do with the post processor converting circles into short straight segments.
Old 05-09-2005, 09:48 AM
joecnc2006's Avatar
www.joescnc.com
maybe it was the way it exported?
ArtCAM substitute? Arnie Rhino 3D 12 09-15-2010 08:31 AM
Plasma G-code with Artcam? coherent ArtCam Pro 4 11-22-2006 07:31 PM
A new feature in Mach3.... ynneb Mach Software (ArtSoft software) 20 09-20-2005 05:53 PM
ArtCam with 2 routers? walter ArtCam Pro 9 06-26-2004 04:10 PM
Software that is compareablr to ArtCAM matt ArtCam Pro 3 06-06-2004 09:04 PM
