Need Help! Roughing and finishing are disjointed
Results 1 to 2 of 2
Thread: Roughing and finishing are disjointed
    Apr 2017
    South Africa
    Question Roughing and finishing are disjointed
    Beginner question.
    I made and test a tool path of a relieve on my machine. I am using Artcam pro 2017 and Mach3.
    I have two tool paths, roughing and finishing.
    When I run the second one (finishing), after having zeroed the Z with the new tool, the operation is starting without considering that the part was already roughed. So basically ignoring completely the previous roughing operation. I see the tool working where the material was already removed by the roughing.
    I have not understood what I am doing wrong.
    I did it using the roughing and finishing combined in the panel "create machine relieve" and also using the Z-Roughing and separately the "create machine relieve" only for the finishing.
    Doesn't matter what I do the two tool paths are always disconnected as I said above.
    I would appreciate some help.
    Felice
    Member ygorek's Avatar
    Oct 2016
    Russian Federation
    Default Re: Roughing and finishing are disjointed
    Use the manual tool change, and the problem will disappear!
