Need Help! FOIL EMBOSSING DIES
Results 1 to 3 of 3
Thread: FOIL EMBOSSING DIES
    May 2017
    Egypt
    Default FOIL EMBOSSING DIES
    hello , I have recently bought a 3 axis cnc machine and i could make female brass dies for foil embossing dies , I used artcam and it worked fine
    but i have a problem regarding the male die , i make the male die by inverting the relief horizontally and then in the z axis , afterwards i added an offset value to the relief about 0.22 m for 200 gsm paper ( i dont know if this value is correct or not ) . finally i have a foil embossing die for paper and it works but the finish on paper isnt satisfactory because some small areas arent foiled and these areas are dispersed all over the design
    some questions are on my mind need answering :
    1 - i make the male die out of acrylic and is this correct ?
    2 - is the offset value for 200 gsm paper i used correct ?
    3 - i heard about plastic boards for making male dies just by press
    please any information will be very useful
    May 2017
    Egypt
    Is my problem too difficult to solve ?
    May 2006
    Default Re: FOIL EMBOSSING DIES
    Are you stretching, compressing, folding the metal int he die?
    Send a picture of the parts and die for analysis.
    Are these the notary dies type ? foil on paper?
    There are no problems which cannot be solved.
    Been doing this too long
FOIL EMBOSSING DIES
FOIL EMBOSSING DIES
