Originally Posted by
Mokra
Do you have a Mach 3 or 4 Setup on your CNC computer that runs your CNC? Most of the time you need to use Artcam to out put a G code. Use Mach three to read the G code. All machines are different and you need to set up each project to your machine. I remember when i was in your position you need to do some research and start slow. It will come together. Lots of ways to do it. Start by looking at your sxcnc control box and youtube from there. Im familar with the G540 set up.
