Results 1 to 8 of 8
Thread: Mirroring Parts
    May 2003
    Mirroring Parts
    Hi
    I am having trouble trying to mirror a part, and I am hoping someone can help me.
    I have drawn a part, with various holes and extrusions etc, and this makes up a right hand side plate of the mechanism I am drawing. I now want to make a mirror image copy of this part to make up the left hand side plate. How can I do this?
    Regards
    Andrew
    Jan 2005
    Use the Scale function. Feature>Scale...then set one of the axis to -1. (negative one)
    May 2003
    Hi
    Thanks for your help, it works perfectly.
    Regards
    Andrew
    Jul 2004
    I ALSO HAD PROBLEMS MIRRORING A PART, E-MAILED ALIBRE AND GOT THE SAME ANSWER. YES IT WORKED BUT I DON'T UNDERSTAND THE LOGIC OF USING A NEGATIVE ONE (1) TO ACCOMPLISH THIS. CAN ANYONE EXPLAIN THIS TO ME?
    THANKS
    Jun 2006
    Using a negative number for scaling one axis is the same as multiplying each coordinate for that axis in your original sketch by that negative number.
    For example, if you had a square that was defined by these coordinates:
    Point 1: 0,0
    Point 2: 0,1
    Point 3: 1,1
    Point 4: 1,0
    And used a scaling factor of X = -1 and Y = 1, your new sketch would have these coordinates:
    Point 1: 0,0
    Point 2: 0,1
    Point 3: -1,1
    Point 4: -1,0
    In effect, the sketch is mirrored about the Y axis.
    Mike
    Jul 2004
    Smile
    MAKES PERFECT SENSE
    THANKS
    May 2006
    Just browsing this forum,
    That -1 to mirror is a stone age way to perform a mirror,
    This is a basic 12 parameter matrix command
    I thought that new software was better than that
    Been doing this too long
    Jan 2005
    I agree...but it is what it is.
    1. Where can I Buy these parts
      By jfh2007 in forum Australia, New Zealand Club house
      Last Post: 02-21-2008, 04:11 PM
    2. Replies: 0
      Last Post: 06-17-2007, 10:16 PM
    3. Parts need... Any help??
      By debutis in forum Parts for Radio Control Models
      Last Post: 08-05-2005, 01:01 AM
    4. 2 parts needs to be done.
      By cnc2k in forum Employment Opportunity
      Last Post: 05-13-2005, 11:17 PM
    5. RFQ - SRC Parts
      By Swami in forum Employment Opportunity
      Last Post: 03-25-2005, 10:14 AM
