Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAD Software > Alibre Design
Alibre Design Discuss Alibre software here.
Old 02-17-2008, 02:38 PM
teamtexas's Avatar
teamtexas is on a distinguished road
Trying to get holes centered!
I'm working on a 3.750 round plate and I want to drill/ cut several shapes through the plate. I need all the holes and shapes to be spaced evenly in a 1.750 ring around the center of the plate. Is there an easy way to do that? I tried using the constraint tool and the center mark, which worked well to keep the holes/shapes .875 from center but they are not spaced evenly from each other.
Old 02-17-2008, 02:56 PM
stevehuckss396's Avatar
stevehuckss396 is on a distinguished road
Draw the first hole at 12 oclock .875 from center.
Click "Feature" on the top menu bar
Then click "Pattern"
Then click "Circular"
When the box pops up input how many holes total and how many degrees apart. Click the box for "Center" and then click the Z axis and you should be good to go.
Old 02-18-2008, 11:33 AM
teamtexas's Avatar
Ok Steve that worked. What about making several different shapes lay out in a circle without making additional copies of them?
Oval holes abcdef General Metalwork Discussion 5 08-11-2007 01:40 PM
Holes? saturnnights SheetCam 2 02-22-2006 12:28 PM
Need help capping holes fossilworld Rhino 3D 10 09-20-2005 07:19 AM
One lead screw off-centered..Will it work? bgolash DIY-CNC Router Table Machines 14 04-02-2005 08:57 AM
holes Xeno PTC Pro/Manufacture 1 09-05-2003 06:11 PM
