Results 1 to 3 of 3
Thread: How to use alibre?
    Registered Apples's Avatar
    Feb 2004
    Australia, Queensland
    How to use alibre?
    How do you use alibre?
    Say I want to draw a trailer frame.
    I need say 2 chassis rails and 4-5 cross runners over the top. I drew my two chassis rails in sketch view then extruded them. Then I went to draw one cross runner but I could not center it properly between the two rails.
    Then I remembered the assemble part of alibre...
    So now I am wondering if I have to draw the individual bits of box steel in the parts function of the program. One at a time. Then go into the assembly part of alibre and build the trailer there?
    Peter
    My little site on MIG welding http://www.learn-how-to-weld.com/mig-welding/
    Gold Member
    Oct 2005
    The assembly method is the way these parametric CAD systems work. Create the "sticks" of tubing or channel you will use, then assemble them into the trailer. Alibre, Solidworks, Pro-E, Inventor, etc. are all pretty similar in this regard.
    Using something like AutoCAD, you would draw all the pieces in the same sketch. Using these 3D CAD packages, you draw all the components separately, then put them together in another file.
    Feb 2004
    Righto, this makes sense so far. Thanks for your help.
  1. Need Help!- DXF to 2D Alibre
    By kawazuki in forum Alibre Design
    Last Post: 09-12-2009, 07:37 PM
  2. Alibre CAM
    By Smitty911 in forum Alibre Design
    Last Post: 12-21-2008, 03:20 AM
  3. Alibre CAM coming in Alibre Expert 10
    By MichaelHenry in forum Alibre Design
    Last Post: 06-16-2007, 02:57 PM
  4. Alibre/ Alibre xpress
    By moyesboy in forum Alibre Design
    Last Post: 01-25-2006, 03:41 PM
  5. Alibre anyone?
    By WOLOG in forum General CAM Discussion
    Last Post: 08-27-2005, 03:44 PM
