Results 1 to 3 of 3
Thread: Linear Feature Pattern - Chamfer?
    Jan 2007
    I am making a fixture in Alibre which has 32 squares which each need the edges chamfered. That's 32*4 = 128 edges. I chamfered one square and tried to use the linear feature pattern tool (convenient, as the squares are in a pattern) but it's giving me the red "x" on the feature pattern in the design explorer.
    Does this mean I cannot linear pattern a chamfer? If so, any suggestions on how to do this? E.g. is there a way to tell Alibre to auto-select all edges in the design that are a specific length?
    Tormach PCNC 1100, SprutCAM, Alibre CAD
    Registered TXFred's Avatar
    Aug 2009
    Austin, TX
    You can select each plane instead of each edge. That means you only have to click 32 times instead of 128.
    If you want to pattern a chamfer, what you'll probable need to do is make a single square, chamfer that, and then pattern both the square and the chamfer.
    Frederic
    [URL="http://www.pure-geometry.com/"]Pure Geometry LLC[/URL]
    Vertical Lathe tool holders and more.
    Jan 2007
    Frederic - Thanks - that does help. I'm still surprised there isn't a way to "bulk" select...
  1. Problem- Dill feature without center drill feature
    By LockTech in forum BobCad-Cam
    Last Post: 08-25-2011, 09:38 AM
  2. Chamfer chamfer mill or ball mill
    By fjbart70 in forum Mastercam
    Last Post: 03-11-2011, 12:27 PM
  3. help with 3d chamfer
    By Justin Cavender in forum Mastercam
    Last Post: 01-23-2011, 04:56 PM
  4. 2D chamfer
    By jcnewbie in forum Mastercam
    Last Post: 10-19-2009, 12:06 AM
  5. Chamfer
    By CharlesM479 in forum Solidworks
    Last Post: 04-12-2007, 12:13 AM
