Results 1 to 5 of 5
Thread: Editing part in assemly
    Feb 2006
    Got a silly question. When you add multiple instances of a part in an assembly, how do you edit one of the parts without it making the changes to all of them?
    Thanks!
    Feb 2006
    Not an easy thing to do?
    Registered TXFred's Avatar
    Aug 2009
    Austin, TX
    You could create a configuration within the part, if you have a version of Alibre that supports that ability. The configuration would be the same part, but with some dimension changes or extra or fewer features.
    Frederic
    [URL="http://www.pure-geometry.com/"]Pure Geometry LLC[/URL]
    Vertical Lathe tool holders and more.
    Feb 2006
    Don't have that unfortunately. Just saved everything as discreet parts. Kind of silly you can't do it within an assembly
    Aug 2009
    Austin, TX
    It's not silly. It's working the way it's meant to. Changes to a part have to propagate to all instances of that part, otherwise you'd be spending hours updating each assembly by hand.
    Since you don't have the configuration function in Alibre, your best option is to copy the part file to a new filename and edit the copy. Then you need to go back to your assembly, and replace the one part you want to change with the modified copy.
    Frederic
    1. Editing G81 macro
      By flannman in forum Mach Wizards, Macros, & Addons
      Last Post: 02-12-2011, 02:20 PM
    2. Newb ? - CAD Part interference & mating part dims
      By pabmartin in forum Mechanical Calculations/Engineering Design
      Last Post: 11-06-2009, 01:18 AM
    3. sheetmetal part? flatten a rolled part?
      By Rich05 in forum Solidworks
      Last Post: 08-12-2009, 11:22 PM
    4. Extended part program editing on 10T
      By guhl in forum Fanuc
      Last Post: 06-04-2009, 09:40 AM
    5. Newbie- Part holding and milling 3D part on 2.5D Mill?
      By john_t_h in forum General Metalwork Discussion
      Last Post: 03-15-2008, 07:35 AM
