Originally Posted by
Farmers Machine
I was at a sheet metal shop that uses solid works. I sat down with the owner to design a stainless steel box with large radius corners, it took about 45 minutes for 2 ends, the middle section and the top. we added legs simular to an old timey washing machine that were tapered from top to bottom and had a large rounded corner. we started with 14" tall legs and after assembly decided to go with 18" tall instead. Roy clicked on the dimension of the solid model leg, and changed it to 18". In 5 seconds the bottom base moved the legs got longer and the taper changed. When he opened up the leg drawing again the legs were modified and 18" tall. Does Alibre have this same ability?
Thank You for all of your help
The Farmer
