Results 1 to 4 of 4
Thread: Printing the drawing
    Jan 2007
    Smile Printing the drawing
    Version 12.1
    clicked on the left icon, draw a part to make an assembly. Drew the part and when I printed it, it came out in color with light blue background and the grid. It was good looking page but used a lot of ink. How do you make it print only the geometry and the dimensions, with a white background?
    Thank You
    The Farmer
    Mar 2006
    At this point, you need to create a drawing of the part or assembly. If you have access to your manual, or the PDF's you can look up the details....or you can use the help files...OR better yet....the tutorials...
    Basically...under the same pulldown menu as the one you used to create the assembly, there is an option for creating the drawing. That is what you're needing..... the art creating a drawing is far more than a single post in a forum can ever dream of covering. Your best friend is the help files provided...
    If you can provide more specific questions, I will be happy to help....Alibre's drawing module is actually pretty powerful...and is what I use everyday...so I can probably guide you through some scenerios
    Jun 2010
    Quote Originally Posted by Farmers Machine View Post
    Version 12.1
    That's printing a copy of the screen display.
    Try File/New/Drawing for a proper drawing.
    Cheers
    Aug 2008
    Sounds like you printed a sketch, not a drawing.
    In order to make drawing there has to be a model.
    I have not done much with drawings in Alibre but what little I have done seemed very simple, creating 3 views automatically. Pretty handy.
    Joe
  1. Need Help!- How do I edit a DWG drawing so I can add my toolpath drawing.
    By SpeedsCustom in forum Autodesk Software (Autocad, Inventor etc)
    Last Post: 10-01-2009, 11:32 PM
  2. Laser printing?
    By jag2x in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 02-25-2009, 08:48 AM
  3. Need Help!- converting imported part drawing to mold drawing
    By msomerville in forum BobCad-Cam
    Last Post: 08-29-2008, 07:56 AM
  4. Printing
    By kenlambert in forum BobCad-Cam
    Last Post: 03-30-2004, 07:22 PM
  5. V19 printing?
    By inthedark in forum BobCad-Cam
    Last Post: 02-28-2004, 03:46 PM
