Making a negative of a part
Results 1 to 4 of 4
Thread: Making a negative of a part
    Sep 2010
    Default Making a negative of a part
    Hello,
    Been struggling with this for a while doing searches and such. For the life of me i cannot figure out how to do a negative of a part. Similar to a mold, i would like to cut out the features of the part in a jig plate for better nesting of the part.
    Any help is appreciated.
    Member awerby's Avatar
    Apr 2004
    Default Re: Making a negative of a part
    It sounds like you need to do a Boolean subtraction. Here's some instructions on how to do it: Alibre Options: Using Boolean Operations in a Part Workspace | Cadalyst
    Sep 2010
    Yep, thats what i thought too. However, when i try to "remove" the part half, it removes improperly and leaves surfaces. Im thinking now I may have a model issue. Its an imported .iges part file which im thinking was not made solid upon import. Is there a way to validate that my part file is a true solid?
    I think that may be my issue.
    Apr 2004
    You might try running some of the "printability" checks - if it has extraneous surfaces incorporated into the model, that should highlight them: 3D Printability Tools
