Hi Guys
Not new at using this software, but it's got me puzzled this time. Dimension Values I've turned on and off at time's to see what my part might look like when put together. Now old drawings have the dimension arrows but no values, even new drawings same thing arrows but no values. Need help thanks
- G2/G3 values
- Newbie- H and D values
- Need Help!- Need to know this dimension of DMU 50e
- need help with I and K values
- Problem- - r values
No, I know its not that because I can zoom in and out of the drawing mode, if it was small i would see something, thanks for the thought.
I wonder if this is to indicate dissociativity from the part? Most software packages will show the dimensions in a particular color to show that it has lost the corresponding part edges. Perhaps Alibre just does not display the value.
Alibre usually displays dimension info in red when it has been disassociated.
The OP should search the Alibre user forum for resolutions to this problem. Seems like video drivers might have been the culprit for others in the past.
Mike
I would look under properties and change the dimension font, could be its not installed on the OPs computer.
It does show up in red when i hover over the arrows with no values, its never happened before. I've had this software for couple years now, and I keep the video drivers up to date.
Hi, I've been using Alibre for some years and never had a problem until today, all my arrows are there but no dimensions???? Did you ever get to the bottom of this? Thanks for any help you can offer.
