Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > AjaxCNC Control Products
AjaxCNC Control Products Discuss Ajax Control systems and project here!
Old 11-25-2009, 02:48 PM
bezelchuck is on a distinguished road
How many axes on Ajax Mach3 based control
Hi
I'm very interested in the new Ajax mach3 system. I see its shown on the Ajax website as taking 4 axes but has 6 encoder inputs.Some of the centroid agents websites are showing similar hardware and stating it can handle up to
8 axis. Is it possible to add another GP104D interface to the ajax system to allow 5 axis and an AC servo spindle drive?
Thanks for any input
Phil
Old 01-17-2010, 11:35 PM
Captain Midnigh is on a distinguished road
Yes, think you can.
Old 01-19-2010, 10:34 PM
cncsnw is on a distinguished road
I would check with Ajax on that. It is my (current) understanding that you cannot daisy-chain GPIO4D units. You might be able to use one GPIO4D and one OPTIC4. The OPTIC4 is a four-axis servo drive interface (like the GPIO4D) but without the PLC I/O capability. Check with Scott to confirm what is currently supported in the hardware, and what hardware is supported by Mach vs. Centroid software.
Old 01-20-2010, 01:34 AM
Yes you can.
DC1 - Single Axis Servo Amplifier- MPU11/Mach3 Based systems ONLY
Our new single axis add-on drive allows you to add MULTIPLE axes to a DC3IOB/MPU11 based systems a single axis at a time (up to 6 total axes) This drive can be used for rotary or linear axes and includes software unlocks for an additional axis. DC1 Single Axis Add-On Drive $395
Old 01-20-2010, 06:39 AM
ajaxscott is on a distinguished road
Originally Posted by bezelchuck View Post
Hi
Phil
Marc is correct.
You can't use two GPIO4D boards together but you can add additional axes (up to 8 currently) by pairing the GPIO4D with an Optic4. The difference between the GPIO4D and the Optic4 is that the GPIO4D provides onboard I/O while the Optic4 does not. The Optic4 provides analog outputs to control up to 4 axes.
The cost to add an Optic4 to a GPIO4D system is $750.00
Regards
Scott Pratt
Old 01-21-2010, 12:49 AM
Rob West is on a distinguished road
Hi Scott
I don’t know if I should add this to this post. Hopefully its OK.
I am looking at doing a retrofit on a Morbidelli U50 I purchased last year.
The “Mach3 CNC Kit For 3rd Party Drives With PLC” looks very interesting as it has the D/A and the Encoders etc. but it is down on I/O.
I am after about 46 inputs and 63 outputs to replace the old Tria 6000 and add some new functions.
How does one add the extra I/O?
What parts and accessories are needed?
And if this is the correct place to ask the question. At what cost? (if not can you please contact me personally)
Regards Rob
Old 01-21-2010, 06:32 AM
Originally Posted by Rob West View Post
Hi Scott
Regards Rob
Hello Rob,
You can currently add I/O in 16/16 increments. Inputs are optically isolated and can be configured for 5/12 or 24VDC. Inputs can also be configured as sourcing or sinking. The outputs are all relay contact closure and are fused fused. All inputs and outputs are terminated at Phoenix type screw connectors which makes them extremely easy to wire.
The I/O boards are available at a cost of $250 for the first board and $175 for additional boards.
Keep in mind that any I/O sent down by Mach (keyboard, joystick etc...) does not consume any physical I/O nor does the Machine control pendant that we offer. -You may not need as much additional I/O as you originally calculated.
We expect to have higher density boards for I/O expansion in the near future.
-I briefly researched the Morbidelli U50 -looks like quite a machine but I couldn't find any information on the motors and drives. If you could email me the make and model info for both the motors and drives, a digital photo of the nameplates would be fantastic, I'll be able to give you more specific information regarding what will be needed to complete the retrofit. You can email me at ssccoott@@aajjaaxxccnncc.com - please remove duplicate characters
Best regards
Scott Pratt
Programming Mach3 by just jogging the axes manually uplb Mach Software (ArtSoft software) 3 11-14-2008 08:06 PM
Use Joystick to control 3 Axes. chithinh Hobbycnc (Products) 37 04-13-2007 05:52 PM
I need help on PC-based for servo control NASR1 Servo Motors and Drives 1 08-14-2006 03:43 PM
Best pc based control for 3d work ? DavyD General CNC (Mill and Lathe) Control Software (NC) 20 12-20-2005 05:01 PM
Need Help With Linux/Ajax control software TR MFG AjaxCNC Control Products 1 02-10-2005 07:50 AM
