| AjaxCNC Control Products Discuss Ajax Control systems and project here! |
I see on the Ajax website that two types of retro kits are available. A Mach3 and a Centroid. Are any of the conversion talked about here, done with Mach3? Is the Mach3 conversion any good? I have a Milltronics Partner 4 with Centurion 4 controller I am going to retrofit. |
| Which package did you go with? The Kit With 3-Axis DC Servo Drive or the Kit For 3rd Party Drives? I spoke to Scott at Ajax, and he is very knowledgeable and friendly to speak with. Captain Midnigh, What kind of problems are you having? What experiences do you have with mach and servo drive setups? I'm actually looking forward to buying this kit but waiting to see what other think about it before I go for it. Dan |
| The Kit With 3-Axis DC Servo Drive. I am suposed to be able to use my original encoders, but they don't seem to work. Scott has been great. Documentation is poor and vague. This should be a simple install, but its like pulling teeth trying to get install details. They need a good installation manual. I get a message saying encoder error, so how do I fix it? |
| You might be able to use the older encoders, but sometimes the old ones draw more current than the new drives can supply. When I was retrofitting my Hurco tm-5, I found a PDF document with the specifications of the encoder I had. Unfortunately that was after we had already changed the encoders to some US Digital models. We couldn't get the old ones working and didn't know why. The current ended up being a lot higher on the old ones than the new US digitals. I wish I had found the info prior, because mounting the new encoders required drilling and modifying the old encoder cases. I'm probably better off in the long run that I do have new encoders though. You might have to run an external 5v supply if the old encoders are drawing too much. Check with Ajax, ask them what their drives can supply for current to the encoders. |
| I am also looking at the Ajax kit. One difference in the kit is that Mach 3 seems to be an easy to use "pretty interface program", the centroid software, which is a bit more money is kind of clunky and old school, kind of like our old machines. I have downloaded it and while i like it, you have to use F keys to control it instead of the mouse like mach. However the centroid program does have shop floor programming capability that is supposed to be pretty good. They will get you an evaluation copy if you ask. I am thinking I will go with the third party drive option. I am a little scared of using their small looking integrated drive. |
FWIW You can use a mouse to select the buttons instead of the F keys if you like. Regards Scott |
#11
| If you are in Windows with a mouse already working, just dbl click the Fkey labels on the screen or the field you want to change. |
#12
| Need Help!- CENTROID M-15 | yingerg | General CNC (Mill and Lathe) Control Software (NC) | 0 | 06-19-2009 07:34 AM |
| centroid | johnray069 | AjaxCNC Control Products | 3 | 01-27-2009 02:20 PM |
| Centroid M -400 help needed | densman | Machine Problems, Solutions , Wireless DNC, serial port | 1 | 01-30-2008 02:48 PM |
| Centroid M400 | lostpinky | AjaxCNC Control Products | 1 | 10-02-2006 09:38 AM |
| Centroid 400 M | DirtGhost | General CNC (Mill and Lathe) Control Software (NC) | 7 | 09-07-2005 06:18 AM |
