| AjaxCNC Control Products Discuss Ajax Control systems and project here! |
Looking for Info On encoder types That have been proven to work with Ajax CNC systems. Thanks for any info
__________________ IF ITS NOT BROKE YOUR NOT TRYING HARD ENOUGH Ashes to ashes , dust to dust , If it wasnt for Harleys the fast lane would rust. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| I have seen Sumtak,Dynapar and Renco encoders used. They are 5 volt differential type. I will be trying some US Digital encoders that were on a Camsoft retrofit in the next couple of weeks and will let you know how they work. In my opinion the $125 that Ajax charges for a new encoder is money well spent. Terry |
Converterk thanks for the reply, I went ahead and ordered the encoders from US DIGITAL # E6D hope they work, Built mounts for my SEM motors over the week end at work so I should know if they work some time this week. Also had to change out the pin in the end of the motor. Went from 5mm to .250 and .875 lenght to make it all work. Seems that you have been doing some retrofits to ajax lately any thing I shound look out for ? Thank Brad
__________________ IF ITS NOT BROKE YOUR NOT TRYING HARD ENOUGH Ashes to ashes , dust to dust , If it wasnt for Harleys the fast lane would rust. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) Last edited by MILLMANM; 12-01-2004 at 10:25 AM. Reason: add pictures |
| dk1 do you mean line driver quads, 9 pin if the US encoders work the are around the same money for 2000ppr 8000 cpr and are easy install thanks Brad
| Hillbilly What an eye , hate to change the subject , but it is a 69 f100 shorty 302 efi, aod, with 20" wheels, almost done, hope by the new year.
| I have finished wiring the US Digital E6D encoders to the system and they seam to work, in the pid parameters they show movement in all 3 axis, but it looks like I have to reverse the y axis to get it reading the right direction
#10
| Don't forget that if the motor direction is right but the encoder is wrong direction, on a differential type you just swop the A & /A pins. Al
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
#11
| MillManm, You do not need to change the encoder wiring at all with an Ajax system. The control does not care which direct the encoder reads, as long as it reads correctly and smoothly. Just swapping the A & A/ will do nothing at all, except not work. The correct proceedure to change encoder direction is to swap the A & B and the A/ & B/.
#12
| I guess I am used to all the motion control cards that I use that use this method, I was not aware that AjaxCnc would be different. Sorry for the mislead. Al
| encoder issues | rutexus | Servo Drives | 13 | 05-21-2006 07:49 PM |
| Ajax CNC encoder mounting positions | Piobaire | AjaxCNC Control Products | 1 | 12-17-2005 06:08 PM |
| What's your max distance to encoder? | murphy625 | General Electronics Discussion | 5 | 05-12-2005 11:57 AM |
| Need encoder recommendation | Swede | General Metal Working Machines | 9 | 10-05-2004 09:01 PM |
| Encoder wiring | balsaman | Gecko Drives | 15 | 12-30-2003 12:01 PM |
