| AjaxCNC Control Products Discuss Ajax Control systems and project here! |
| Hey, I have a centroid m-400 control on my little bedmill and have a couple of questions. 1. What are the keystrokes to get to the C:/ prompt from the main screen level? I had done this before but failed to write them down. 2. I'm trying to set up communication between my offline computer and the centroid control via the ethernet connection but I cant get my computer to see the mill control. Thanks in advance |
| Have you tried control+break? I have an older pc based system that uses this. Al
__________________ “Logic will get you from A to B. Imagination will take you everywhere.” Albert E. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
| ValleyFab, Hello. To enter DOS from the main screen of CNC7, press <ctrl><alt><x>. For assistance setting up your control for networking, contact your dealer and he will be glad to help you out.
__________________ Scott_bob |
| ctrl-alt-x is correct as for networking it, dont call up a tech support company for your problem. there is a much much much easier way to do it. install windows 98. yup very easy and works well. people will tell you not to do it because it might mess up your controller, I know a shop with 17 m400's, and every one of them has windows on it and they all work just fine. the only problem i've ever seen with the m400 is overheating, but that was solved by adding another fan into the mix and now everything is fine. hope this helps you out |
| forgot to mention the easiest way to do this. pull the back off the m400 control, attatch a cd-rom ghetto style and either install 98 via cd rom or a way i like to do it because you end up disconnecting the cd rom is to just copy all the 98 files over to a directory called "98install" or something similar and run the setup from there. good luck |
how does the win 98 work on m400 controls without a hard drive. Mine has a compact flash card which is 128 mb thanks bill
__________________ Bill Griffin grifftek@grifftek.com www.grifftek.com/grifftek |
| sorry for the delay in response. to be honest i dont know, i've always used ones with hd's. anyway if it does not have one it would not be hard at all to install one in there and put 98 on it. personally that is what i would do since hd's are pretty cheap any more. if you have any questions or anything or i wasn't specific enough on what would be an easy solution let me know. gl |
#10
| I want to be able to push a file from a remote pc to the centroid 400 control. Via cable connected to the comport. Does anyone know how to do this. I don't have a network card installed and I don't want to add any additional software to the control. |
#11
| MrTrim: the only thing i've seen similar to that is dnc max and you would still need a network port. one thing though i've never seen a centroid 400 based motherboard that didn't have a nic built in. you may want to do a little digging and see if they just hid it or were sneaky about something. |
| G-Code to DXF | WayneHill | OpenSource Software | 189 | 01-30-2012 11:15 AM |
| EdgeCAM Post for Centroid Control | kenmcd | Post Processor Files | 1 | 03-23-2008 09:23 PM |
| Centroid M -400 help needed | densman | Machine Problems, Solutions , Wireless DNC, serial port | 1 | 01-30-2008 03:48 PM |
| 4 axis control board question | cnctoolman | Hobbycnc (Products) | 1 | 04-01-2005 04:30 PM |
| Parallel Port / Relay Control Question | Verboten | Computers and Networking | 7 | 12-21-2004 05:17 PM |
