| AjaxCNC Control Products Discuss Ajax Control systems and project here! |
#13
The boss 5 bridgeport with a ajax retrofit works great, the only thing you have to be prepared for is to get the keways on the timing belt pulleys that fit on the motors need to be opened up to 3/16" key as the origonal is a 3/32" woodroffe key. Also the motor mount on the Z axis needs a 1/8" spacer plate on the face as the bore in the casting is not big enough bore to accept the motor register boss. Apart from these points which are not mentioned in the instructions it is a relatively simple upgrade. GOOD LUCK Colin |
#14
Colin The Ajax retrofit was a easy one , As I am electricly chalanged. but my series 2 mill is macking chips, getting ready to try a 3d model to see how good it is. good buy Brad
__________________ IF ITS NOT BROKE YOUR NOT TRYING HARD ENOUGH Ashes to ashes , dust to dust , If it wasnt for Harleys the fast lane would rust. (Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
#16
| o yes need to get the finished photos Sad to say I got her running but found a 2nd job , 80hrs week , so no time to play with her . but some day soon.
#17
Im new in this forum, I need help in retroffiting a 4x8' router table, I bought camsoft software but they don't want to help me with the installation process. does any one out there has any experience doing retroffiting? Im located in Pico Rivera, CA my email is claudiod@verizon.net |
#18
| If its Camsoft help you need, you might want to post in the Camsoft forum here, There are a few of us that have used Camsoft in the past. Al.
#19
| Originaly this mill had a Dynapath system 20. That control needed a rather pricey repair so we did the retrofit. After some trouble at first, coused by too slow a computer, it now performs very well. We use it mainly for secoundary opperations, one of parts, or to handle over flow from our VMC's. It runs every day. We cut some rather complex parts in it too. Sorry for the mess it has been cutting delrin for days. |
| cnc mill retrofit | jimsuhr | General Electronics Discussion | 45 | 09-10-2008 11:01 AM |
| Bridgeport Boss Retrofit help | moto21 | Bridgeport and Hardinge Mills | 7 | 06-09-2005 10:32 PM |
| "Bolt-on" CNC retrofit thoughts | kong | General Metal Working Machines | 4 | 02-20-2005 12:11 PM |
| Low cost machining centre retrofit | motordude | General Metal Working Machines | 2 | 01-07-2005 01:32 AM |
| Choosing a Power Supply for Retrofit? | pfeist | General Metal Working Machines | 4 | 05-23-2004 10:36 PM |
