Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > AjaxCNC Control Products
AjaxCNC Control Products Discuss Ajax Control systems and project here!
  #13   Ban this user!
Old 03-13-2008, 11:03 PM
pzzamakr1980 is on a distinguished road
Why does this mill strike me as being very similar to the usual gearhead mill sold by grizzly and outfitted with a few nicer items. If you are looking at this machine, why not check out the Industrial Hobbies CNC ready to-go mill which has considerably larger travels and is made specifically for IH to their specs. Ground ways, precision cut gears, servo driven, optical limits, coolant-tight sealed system. This machine seems no nicer than an IH and costs 4000 more. The IH also benefits from having a much larger headstock assembly which prevents that head tram problem CNCdragon mentioned.
I've never used any cnc system other than Mach3, which is windows based, but I run my little benchtop cnc mill every single day of the week using that system and its never let me down. I also was completely self taught and it was very easy to learn, and can do anything that a true cnc control system will do. At least anything I've ever seen.
RFQ - milling work on 1/4" wide tool steel - may need azis mill or right-angle mill pendentive Employment Opportunity 7 01-21-2007 07:56 PM
Machining In The Living Room aka A Mill In A Desk Too_Many_Tools Benchtop Machines 11 05-24-2006 01:11 PM
Are there any centroid (or ajax) users here with tool changing mill? Grifftek AjaxCNC Control Products 13 02-07-2006 01:13 PM
