Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > AjaxCNC Control Products
AjaxCNC Control Products Discuss Ajax Control systems and project here!
Old 03-06-2007, 09:56 PM
Tazzer is on a distinguished road
Feedrate Override by Keyboard
Using the M-4oo controller is it possible to control feedrate by the keyboard while a program is running. I have seen the =+ and shift =+ but it doesn't do anything. Any suggestions
Old 03-26-2007, 02:16 AM
*Registered*
MarcL is on a distinguished road
No.
The keyboard shortcuts are only available when using keyboard control with no jog panel installed (i.e. the "Console Type" selection on the Control Configuration screen is "Keyboard"). You can't select keyboard control without losing the use of your built-in jog panel.
I presume this is related to the keypad question: you are looking for a way to have remote feedrate override control, out of reach of the built-in jog panel.
Unfortunately, I don't think there is any good way to do that.
Best bet for solving both problems might be to buy the M39 pendant enclosure, cable, and internal plug pigtail so you can turn your built-in jog panel into a removable walkaround pendant.
- Marc
Anilam Crusader II runs with override wddanie Machine Problems, Solutions , Wireless DNC, serial port 1 09-27-2008 02:20 PM
spindle override imca38x Fadal 1 09-09-2005 12:25 PM
Feed Override SCOJEN DIY-CNC Router Table Machines 0 01-24-2005 01:56 PM
limit switch override swarfmacdaddy TurboCNC 5 12-12-2004 04:47 AM
Feedrate Override JFettig TurboCNC 2 12-09-2004 07:17 PM
