Results 1 to 3 of 3
Thread: Key Remapping
    Jul 2003
    Colorado
    Key Remapping
    Anyone know if it is possible to remap the shortcut keys on a Centroid M-400
    Such as instead of Alt+S for cycle start you can remap it to number 8 instead.
    Reason asking I have a large 5 axis that I am trying to get up and running and I would to be able to have a secondary controller on the other side of the machine. I would like to simply use a keypad instead of a full sized keyboard.
    Any suggestions would be great.
    Jul 2006
    I would like to know this as well. I am in a simular situation if this is possible can someone explain how this can be done
    Banned
    Mar 2007
    No, that is not possible.
    If you need many of the keyboard shortcuts, you might be able to add a programmable keypad (one that lets you program its keys to generate whatever key sequences you want, instead of just being a number pad).
    If all you need is a remote cycle start button (and maybe a remote feed hold and/or cycle cancel as well), that could be done through your PLC. Likely it will require some editing of your PLC programs, but that is something a competent Centroid tech can help you through.
    - Marc
