Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > AjaxCNC Control Products
AjaxCNC Control Products Discuss Ajax Control systems and project here!
Old 02-07-2007, 07:17 PM
George C is on a distinguished road
Programing AUX buttons
Hello,
I'm a long time lurker and a new poster so please excuse me if I ask obvious questions.
I have a Centroid M400 and wonder if anyone has an idea how to program the AUX buttons so that they can activate as push-push functions for a work holding system?
Has anyone bisected the MPG handwheel assembly? What are the specs on the encoder? Plug pinout?
Thanks,
George
Old 02-07-2007, 09:30 PM
jnutter is on a distinguished road
Do you have any of the documentation? It should cover how to program the PLC. I was looking it over the night before last. Looks pretty simple. You can access all the buttons and all the outputs that way and tie them together in any way you wish.
Ajax might write you a custom PLC program if you don't want to get into that.
Old 02-07-2007, 09:39 PM
Thanks for the reply.
I have drawings and owners manuals but nothing about the PLC. I know it ought to be a simple piece of code to make a clean solution rather than a hardware kludge. I suspect that it's a secret so changes can be $old.
Old 02-10-2007, 02:33 PM
Shizzlemah is on a distinguished road
no secret
depending on your SW version, those buttons are mapped to PLC inputs,
and those inputs automatically trigger some M-codes.
You can map those M-functions over to call M93 / M94 to turn on or off PLC outputs. With the user variables you can add some smarts to it.
Use the CNC10.M60 (example) file to map commands for the M60 function (one of the aux buttons)
This is all without getting into the PLC. PLC is documented, slightly, holler if you need more on that route but I would recommend against it. You can do it all through the CNC side of the PLC without changing ladder. Just do it in SW.
Broken Buttons Hitachi-Seiki HT_20SII Ken General Metal Working Machines 1 04-21-2008 02:28 PM
CAM programing kenlambert G-Code Programing 1 02-03-2006 01:03 AM
Bridgeports hidden buttons on cncs leggetmachine Bridgeport and Hardinge Mills 5 08-19-2005 01:22 AM
Some of my buttons are missing??? boxwood Forum Questions or Problems 2 05-17-2004 08:00 AM
Lathe programing help smitty TurboCNC 24 06-23-2003 11:39 AM
