Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > AjaxCNC Control Products
AjaxCNC Control Products Discuss Ajax Control systems and project here!
Old 09-19-2006, 06:47 AM
camtd is on a distinguished road
Satisified Customers
Hi
I am considering this control for a 1984 Bostomatic with a toolchanger and a 1981 Mori Seiki sl3 lathe.
I need reliability and accuracy for a fast pace shop that produces aerospace parts. tolerances within .0002 all day.
I also need tech support when I call.
I do have a recommended retrofitter.
Would I be extremly happy or unhappy with a purchase of this product?
Thank You
Old 09-19-2006, 07:59 AM
Karl_T's Avatar
Karl_T is on a distinguished road
It will all depend on the quality of your retro-fitter. There will be a lot of PLC work here that will not be part of your control. Are you getting a Centroid or Ajax control? Same company, Ajax is the lower end for cost and service.
I have not used Ajax, but I've done a lot of other controls. My favorite is Camsoft.
Karl
Old 09-21-2006, 03:36 PM
luiguicam is on a distinguished road
You can jump on Ajax without fear. I did it. It is a lot better than they (ajax people) say. I used to work with a Bostomatic vector 32 1995 that cost new $230.000.00, I would say with Ajax you can get the same performance with $4000.00
Good Luck.
Old 09-21-2006, 05:16 PM
Shizzlemah is on a distinguished road
Check the lathe retrofit thread.
I got a centroid, very disastified. I would ONLY recommend the centroid in one case - If you are making parts for the iranian nuclear program.
On the surface, my centroid retrofit quote was about $4k less than a fanuc retrofit. Centroid screwed me out of $3k in options, and could use another $2k of spindle drive... So, I have trouble sleeping with this POS knowing a fanuc would have been cheaper and a thousand times better.
Old 11-16-2006, 07:24 PM
DRD DRD is offline
DRD is on a distinguished road
I just got my lagun mill up and running. I has new ball screws, with elrod machine brackets, and all Ajax controls and motors.
I had a few problems with the install. But with the Help of Ajax, she runs like a charm. I use this machine to digitize racing cylinder heads, and reproduce the machine work on raw castings.
The plc will be the biggest challenge for you, but Ajax will set you up.
I am very happy with my controls.
Thumbs up with Ajax!
