I used a centroid retrofit pacakge and wasn't impressed. It is a milling controller and I found a lot of the turning functions were cobbled together.
Cutter comp is hokey- hope you like programming to the center of your insert radius. Doesn't support a barfeed - no interlock logic, etc. Be prepared to launch a few bars through the backside of the machine...
Especially considering the fact that it was a 'package' led me to believe they had built one or two before and tried them out. Clearly not the case. They would not supply me with params for the application (package,mind you!) and there was some trail and error. For nearly a year the X jog buttons on the pendant worked the wrong way. The X+ button moved X- and vice versa. It took nearly a year to get them to BELIEVE that was really happening. They also stiffed me on some options and it was a waste of $15k. Glad I only did one machine as a tester.
In all honesty this was a centroid pacakge. But if you can get the same thing from ajax, just save the money and instead go for a nice, sharp stick in the eye.
Originally Posted by NC Cams
LinkBack URL
About LinkBacks
right now I cannot sell my customers a through-the-parallel-port system.
