Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > AjaxCNC Control Products
AjaxCNC Control Products Discuss Ajax Control systems and project here!
  #13   Ban this user!
Old 02-01-2006, 06:30 PM
Michael M is on a distinguished road
I have to do manual tool changes on my Tree 325 (CAT40) but I thought I'd mention that I just got my TT1 tool setter installed today, and that sure is slick. I double checked it against my manual numbers and I was usually within .0015" of the TT1, but I suspect the TT1 will be more consistent over all, not to mention a lot faster.
The digitizer uses the same port so I'm hoping it works too but I'll give that a try tomorrow and see how it does for probing/centering/edge finding.
cheers,
Michael
  #14   Ban this user!
Old 02-07-2006, 01:13 PM
cncrich is on a distinguished road
Tool Changer
Originally Posted by Grifftek
I have an Atrump b5ac machining center with 16 pos tool changer. I want to have the tool changer macro modified to allow me to use more than 16 tools. In otherwords, if I call a tool above the 16 bins, it will put the current tool away in a bin (if it came from a bin) and then ask you to insert the next tool
Id also like to have access to the tool eject button when setting offsets without exiting from the offset screen.
Anyone else have any input on this?
Bill Griffin
If you have a newer software version you can modify the program to do just about anything. It can be a daunting task to someone who's never dealt with modifying the PLC programs on a Centroid control. You can contact Atrump and they could hook you up.
