Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > AjaxCNC Control Products
AjaxCNC Control Products Discuss Ajax Control systems and project here!
Old 04-07-2011, 12:38 PM
Michael M is on a distinguished road
Centroid probe/tool setter splitter box
I've got a Centroid conversion on my Tree J425 mill. The probe and TT1 tool setter are very handy, but the plug they share is on the side of a cabinet mounted to the back of the machine. To get there from the front of the machine where the console is I have to make a big loop around all the stuff packed into the garage, and then back again to operate the mill, then back to unplug, then back to the console.
This was getting pretty old so I made a "splitter box" so I could have the probe and TT1 plugged in all the time and just flip toggle switches to change modes.
This does make it possible to defeat the safety feature in the control that prevents spindle operation when the probe is detected. But I'm the only one who uses the machine and the probe is inserted, used, and taken out when finished so I don't think there is much chance I'll run the spindle with the probe in place.
I ordered the parts from Mouser.com and here's a list of what I used. A EE friend suggested these toggle switches with gold-plated contacts as I live near the beach and he figured they would be more resistant to corrosion.
571-1-206062-6 Tyco Standard Circular Connectors STD CABLE CLAMP 11
571-2064331 Tyco Standard Circular Connectors RECP SQUARE REV 11-8
571-2064341 Tyco Standard Circular Connectors PLUG REVERSE 11-8
4 571-665693 Tyco Standard Circular Connectors SOLDER SKT
5 571-665703 Tyco Standard Circular Connectors SOLDER PIN
6 546-1550Z107BK Hammond Enclosures, Boxes, & Cases 4.94 x 3.165 x 1.606
633-M2042SS1G01-RO NKK Toggle Switches 4PDT ON-NONE-ON
The enclosure was about $20, and while I could have made a box this one has a nice rubber o-ring seal and good paint and it seemed likely to be hundreds of dollars cheaper than whatever I made.
The AMP plugs match the ones used by Centroid.
Total cost was under $100. If I had to do it over again I'd order crimp terminals and the tools to install them as I found electronics soldering is not one of my strong skills. I got it done, but it was a frustrating afternoon.
cheers,
Michael
Old 05-18-2011, 07:22 AM
waterfxmatt is on a distinguished road
Thanks for the PM Advice. Finally got mine all put together. Since I knew i was not going to have probe wire plugged in all the time i also added a cap to that plug to keep moisture out. Also found some little rubber boots that protect the switches from moisture also.
Overall a fun little project that will save me a lot of headache running back and forth to rear of machine.
Old 05-18-2011, 08:58 AM
Nice job! The engraving makes it look like a "real" part, doesn't it?
cheers,
Michael
Need Help!- AL-2 with tool setter PirateMachinist Mori lathes 7 10-05-2010 09:11 AM
Need Help!- tool setter korte1 Mazak, Mitsubishi, Mazatrol 0 04-06-2010 08:21 AM
Optical Tool Setter / Probe XxLT250RxX Haas Mills 7 03-11-2010 02:15 PM
Need Help!- Tool Setter Macro for M-V60C and Metrol Setter mitshack Mazak, Mitsubishi, Mazatrol 0 10-06-2008 08:39 AM
Need Help!- Tool setter macro for M-V60C and Metrol setter mitshack General CNC (Mill and Lathe) Control Software (NC) 0 10-06-2008 08:38 AM
