Go Back   CNCzone.com-The Largest Machinist Community on the net! > Machine Controllers Software and Solutions > AjaxCNC Control Products
AjaxCNC Control Products Discuss Ajax Control systems and project here!
Old 12-13-2010, 07:02 PM
electromech31 is on a distinguished road
Centriod Giving error message
Our Centriod is giving a "NO INPUT SIGNAL" error on startup, then screen goes black. She beeps, but I couldnt tell you what that means. open console and al the fans are on. Any advice???
Mill is a M400S.
Old 12-13-2010, 11:44 PM
cncsnw is on a distinguished road
"No input signal" is typically the sort of thing the LCD monitor says when it is powered up, but it is not receiving any VGA signal from the computer. This usually means either that the computer did not begin to boot, or that the VGA cable from the computer to the LCD panel is loose or disconnected.
Is the CPU fan on the Celeron or AMD processor (upper center of the motherboard) running?
If you wait a couple minutes, do any lights in the jog panel (other than the spindle 100% and CW lights) come on? At that point, if you release the emergency stop, can you switch to Continuous jog mode and jog the axes around?
If you can do those things, then it is just a display problem: probably a loose VGA connection.
If the other jog panel LEDs never come on, and you can't jog, then the computer is not booting. In that case it is probably a motherboard issue, though it could just be the MATX power supply in the console. The power supply is less likely in your case, if the console fans keep running, but it is not out of the question.
Need Help!- Error message CR1 etc. NPI Bridgeport and Hardinge Mills 8 09-24-2010 09:34 PM
LC-40 giving spindle drive error on startup - how to bypass? SRT Mike Okuma 5 07-20-2010 04:12 AM
Need Help!- How do I fix this error message? Patt66 General CNC (Mill and Lathe) Control Software (NC) 3 02-09-2010 12:22 PM
Error Message Mastercam User Mastercam 13 05-10-2008 10:31 AM
G83 error message HBFixedGear Fadal 14 01-30-2007 09:42 AM
