Need Help! New Centroid on Gantry router.
Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: New Centroid on Gantry router.
    Aug 2005
    Default New Centroid on Gantry router.
    I have a new 3 axis Centoid put on a lead screw gantry router. 4x4 Old Phoenix.
    I have gone thru the servo tuning. Used auto tune but it updates to high numbers. The servo runs violently.
    I tuned to waveforms to look good but when running short moves in XYZ on a job it bangs lead screw hard as if there is play in the lead screw nut. There is no backlash that I can measure.
    Relative to speeds on router on normal router I'm running slow. 100IPM in XY and 50 in Z.
    There doesn't appear to be any dampening on the short moves. I can run a large move point A to Point B at 350IPM and it stops on a dime.
    but when running planer moves in XZ or YZ and very short moves it's banging lead screw. The cut in material looks very choppy.
    Not like my Bridgeport, the XY axis have no load per say. With the belt off, I can spin the drive pulley by hand and X axis will coast a few inches without any effort under its own momentum.
    Any ideas?
    Rob
    Moderator cnckeith's Avatar
    Jun 2007
    Default Re: New Centroid on Gantry router.
    Rob,
    Hello. More information is needed.
    Ac or dc servos? what size servos?
    Overall turns ratio of the router?
    Please post a 'report.zip' file of the cnc control configuration. you can make one of these from the util menu.
    do you have an internet connection on the CNCPC?
    please include the g code program that exhibits the issue.
    -cnckeith
    Aug 2005
    Quote Originally Posted by cnckeith View Post
    Rob,
    -cnckeith
    I'm not at my shop at moment. AC servo. 2:1 ratio.
    There are no errors. Just hard motion.
    I can get report.
    Here is a photo of the servo parms
    Rob
    Attached Thumbnails Attached Thumbnails New Centroid on Gantry router.-img_0530-jpg
    Aug 2005
    I forgot I had a report.
    See attached
    Rob
    Attached Files Attached Files
    Jun 2007
    thanks..
    what size and type ac motors on each axis please?
    Jun 2007
    the report file provided is from 3-22-17 have you made any changes since then?
    Quote Originally Posted by artracing View Post
    See attached
    Rob
  7. #7
    Jun 2007
    is this a new control? or a upgrade of an older control? just trying to figure out what drives, motors, controller you have.. got some photos?
  8. #8
    Aug 2005
    No changes.
    oops, DC motors.
    I'll have to get the motor info later when I go to my shop.
    This machine had an old Centroid on it. Motors are still common today from what I remember
  9. #9
    Aug 2005
    Brand new 3 axis Centroid. Motors original used with old Centroid. The router is old Phoenix. 4X4
  10. #10
    Jun 2007
    ok.. are you using allin1dc? if so, does it have the 12 amp or 15 amp servo drive? (make a difference in tuning)
    servo motor info is critical to proper tuning when reusing old servos. so please post that information. photos of motors and data plate are great.
    how did you determine the base pid values currently being used?
    many old pheonix routers came with SEM DC servos. If that is what your machine has then the base PID values shown in the report file are incorrect.
    if you have a SEM 29 inlb servo with 12 amp Allin1dc servo drive then the base PID should be Kp=1 Ki=.00391, Kd=15 and limit= 32000 for each axis.
    then you can run autotune again with these proper motor matching base PID values.
    after that post a fresh report file and i'll offer advice on fine hand tuning of Ka and Accell.
    Please post the g code program you are running as well. so i can see what the vectors look like.
  11. #11
    Aug 2005
    The motors are SEM. Ill got to my shop now. Back in 15 minutes/
    PID were a generic starting point and seat of the pants.
    I am only using servo motor from original. Everything else was scrapped. It was never not running.
    Not sure what AMP i'll get it shortly
    Ro
  12. #12
    Aug 2005
    Here is the code in problem area.
    I cant give all of it. Private contract
  13. #13
    Aug 2005
    First plate is Z and other is same motor X and Y
    Attached Thumbnails Attached Thumbnails New Centroid on Gantry router.-img_0622-jpg   New Centroid on Gantry router.-img_0623-jpg   New Centroid on Gantry router.-img_0624-jpg   New Centroid on Gantry router.-img_0625-jpg
    New Centroid on Gantry router.-img_0626-jpg
  14. #14
    Aug 2005
    Current PID screen and the beast machine.
    Attached Thumbnails Attached Thumbnails New Centroid on Gantry router.-img_0627-jpg   New Centroid on Gantry router.-img_0628-jpg
  15. #15
    Jun 2007
    thanks.. see post below
  16. #16
    Jun 2007
    ok.. thanks for the photos.. fyi...you do not have a "new" centroid. this is the legacy upgrade kit that allows you to use the old existing servo drive and plc.
    so to solve your issue. set the base PID parameters to
    Kp=1 Ki=.00391, Kd=15 and limit= 32000 for each axis. then rerun auto tune. and then post a fresh report so i can see the results and then i'll advise you on other tweaks to smooth things out.
  17. #17
    Aug 2005
    Will do. Thanks much.
  18. #18
    Jun 2007
    and once you get base pid set in the ballpark..follow this video for final manual tuning.
  19. #19
    Aug 2005
    All three axis are failing "idle to high and releasing power" after auto tune.
    I'll go into tuning again.
    Here is the PID current with your numbers and auto tune results
    Attached Thumbnails Attached Thumbnails New Centroid on Gantry router.-img_0636-jpg   New Centroid on Gantry router.-img_0635-jpg
  20. #20
    Jun 2007
    reduce kd probably end up around 2-4 for kd with such a light system. be careful when playing with kd as if you put too much or too little the system can go into oscillation so have your hand on the estop.
    if you can get a good internet connection to the cncpc then we can tune these motors for you remotely.
