Posting a multiple WCS post on 5 axis mill without using rotary moves
Results 1 to 4 of 4
Thread: Posting a multiple WCS post on 5 axis mill without using rotary moves
    Apr 2005
    Default Posting a multiple WCS post on 5 axis mill without using rotary moves
    I am quite new to Mastercam and am using x4 on a Centroid machine made for 5 axis CNC cylinder head porting with no tool changer. I have a program using two wcs to perform the first op of a part in one vise and the backside of the part in a second vise. When running each program individually the wcs work great.
    Because I do not have a tool changer, I combined the operations into one file, including the wcs for each op, and then re-sorted to arrange the ops as appropriate to machine each portion of the front and back with each tool to avoid duplicate tool changes.
    I assumed this would post a g57 for the front and a g58 for the rear to change each op as required. Instead, a rotary move is being added to flip the part. The part is all programmed in one file, and the wcs are 180° apart, however holding the part in manner suitable for rotary use is not possible, especially since I already have soft jaws machined for each vise.
    Any pointers on a way to tweak the post to prevent rotary use? I tried a generic 3 axis post, and the coordinate system acts as I wanted it (calling the new wcs each time as required), however it is very generic and I am ot sure if the other pars of the post are appropriate.
    Thanks for any feedback.
    John
    Moderator cnckeith's Avatar
    Jun 2007
    Default Re: Posting a multiple WCS post on 5 axis mill without using rotary moves
    John, Hello. Send an email to our 5axis tech support team at fiveaxis@centroidcnc.com and they will be glad to help you out. Keith
    Apr 2005
    Will do Keith, thanks very much,
    John
    Dec 2016
    John, we received your email I replied but there is a problem with your email address as the email was kicked back. Please call into Centroid 814-353-9256.
