Originally Posted by
Marty_Escarcega
Good morning Scott, you were up early, I surely didn't expect you to work on it or look at this until business hours. I do appreciate it. That said, I think you forgot the attachment.
So AUX 1 and AUX 2 are the ones I may change the settings in the parameter, (65 & 66) based on the gear range and its ratio I select. Leave Aux 3 alone which is assumed to be 1:1
I understand your position on the machine and the selection/decision a user makes. Since I can change the values in 65 & 66, then I can experiment with the ratios and gear selections. In low speed, I would rather have the motor running fast enough for the fan to keep it cool.
Thank you to Marc as well for picking up on the issue. I appreciate your chiming in. I enjoy the control work and this is my first experience with Centroid. I see it is a very powerful control provided you understand it and what it can do. If you have any other comments about this issue or if you noted anything in the report file that caught your attention, feel free to mention it.
Scott, I'll look for the attachment after you've had a cup of coffee and are back to work. :-)
I hope you both have a great day!
Marty
