cnckeith is somewhat correct but the filename cncm.hom is for a Centroid CNC11 system and if this is an M15, you will not have a file called cncm.hom. He is correct in that you will need to modify the .hom file and replace the M91 with an M92 or vice versa for that particular axis. The attached tech bulletin should help you out.
