Results 1 to 2 of 2
Thread: Can you give only a few point why you are better than mach3?
    Jun 2011
    I got no response in the flashcut forum. So I'm about to dive into the mach3 demo. Before I do I wanted to give you look.
    I have been doing some reading but the problem is I don't have alot of time to waste.
    I need a good solid product. I want the best. No time to try everything.
    I would also like to try yours.
    Sep 2011
    One thing to be aware of on Abilities g-code controller is that it appears to be rather limited in it's support of a lot of industry standard gcode... This is based on a reading of their manual:
    No G20/G21/G70/G71 for inch/metric selection. No G52/G53/G92 work offsets. No way to set G54..G59 work offsets from the program. G04 dwell function is non-standard (it is modal and only works with canned cycles). No contouring/exact stop/path mode control with gcodes. No scaling/rotations/mirroring/parametric progamming. You have to use two digits for gcodes... like G01... G1 won't work.
    A real STUPID thing is the I J K values in arcs that are not in the XY plane. EVERY other controller that I have seen associates X and I, Y and J, and Z and K no matter what plane you are cutting in. Ability always uses I and J for the axes specified in the G17/G18/G19 commands and K for the other axis. This can cause some major headaches in using existing code or post-processor output.
    Also, arcs are cut as a series of line segments... you can configure the program to alter the resolution of the line segments... but why the heck should you have to do that? Forty year old CNC controls could cut smooth arcs!
  1. Weeke Point to Point experiance
    By Weeke08 in forum CNC Machining Centers
    Last Post: 05-20-2011, 02:01 PM
  2. Start Point to Mach3
    By grandpa jay in forum CamBam
    Last Post: 02-24-2011, 07:39 AM
  3. Busellato Optima Point To point
    By Malacara in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 12-11-2007, 07:22 PM
  4. converting point to point programs
    By kevinwd1 in forum General CAM Discussion
    Last Post: 06-11-2007, 12:45 PM
  5. Load Mach3 point clouds into AutoCAD
    By ger21 in forum Autodesk Software (Autocad, Inventor etc)
    Last Post: 03-04-2007, 03:31 PM
