Old 08-27-2005, 02:07 PM
Darren Darren is offline
Darren is on a distinguished road
You opinion on my plan? Updated: DXF and Pics of parts included
EDIT: I have attached a jpg rendering of my design as well as a DXF file to this post. The plate aluminum for the gantry is 3/8" thick, is that too thin? I don't have 1/2" and had the 3/8" already. Should I put ribs on the outside to add rigidity? The gantry sides are 21" tall, it rides on 1" X 48" supported rails. The Z axis rides on 3/4" X 18" supported rails and final axis is 3/4" X 24" and will also be supported now.
I have all my linear motion bearings and servos with all the aluminum I think I'll be needing. I have one question though. I have two STEEL "C" channel beams that I am considering using to mount my gantry rails to. I'm wondering if it is a good idea to use the steel and mount my rails to it. It seems to be fairly true. Does anyone see any reason not to use that approach. If you have other ideas based on the pics I have provided please let me know!
I have a pic to illustrate my idea for mounting to the steel. I've seen it before:
The two angle aluminum pieces you see will be at the front and back and the steel beams will be mounted above them with the gantry connected underneath where I will connect to the leadscrew nut.
Here are some other shots of the rest of my material:
This is the piece I intend to use to bridge the gantry:
This is a shot of the plate aluminum, gantry bridge piece, and my Y and Z axis linear motion parts:
Extruded aluminum I intend to use to form the table:
The rest of my plate aluminum:
