Don't forget the mill....infact it would be first over the drill press.
Surface scribe/gage...is the weighted base, column and scribe.
Tapping block...you can make your own from wood, steel or aluminum...they are pretty pricey otherwise...like 40 USD.
Test Indicators are the dial gauges you mention (Fowler, Mituoyo, Starett) 0.0005 inch as a minimum...or 0.127mm...get one with the plunger and the lever kind. You'll also need a magnetic indicator holder and one that you can chuck up in your spindle. |
