[QUOTE=I also noticed that the z depth is not constant for the entire arch profile but continually changing. I just thought that the z depth would be constant. Anyone else noticed this?
Jason[/QUOTE]
I found out too the depth is automatically determined by the angle of the cutter and the width of the area you are cutting, sometimes the width is greater than the cutter dia and when calculating the cut path it will tell you your cutter is not wide enough to cut the path.
Some of the signs I have done use the regular V carve for certain design parts, then profile paths for the rest.
I use 60^ and 90^ bits currently and plan to try the 120^ (which should cut a wider, shallower path)
Dean |
