Coordinates modal and / for rapids | | In OnecncXP:
More Shadow/Bandit peculiarities to deal with: these controllers require a "/" before each named axis on a Rapid move. This is not hard to do in the OnecncXP, but there is a problem with the slashes that are not needed when coordinate output is modal.
Example:
/X1. /Y1. /Z1.
/ / /Z0. (no movement in X and Y).
Any trick to get around this? I could run with Coordinate output modal unchecked, but this makes for more stuff to transmit for DNC, as well as cluttering up the code a bit with redundant stuff.
Thanks.
__________________ First you get good, then you get fast. Then grouchiness sets in.
(Note: The opinions expressed in this post are my own and are not necessarily those of CNCzone and its management) |
