It could be, but I haven't seen a machine where that was the case. It may be a fixed parameter in the model settings (which you may be able to edit).
If you use the manual jog keys can you exceed the limits? If not, then I would say you are correct - a firmware setting or mechanical/limit stop.
Zax. |
