Originally Posted by Jimmy Southern mikeschn,
Ger21's conduit design can be done without cnc If you have a good router and a laminate trimmer bit with a bearing. All you have to do is make a simple jig to hold the form that the bit follows & the work piece.
Doesn't the laminate trimmer force you to cut the entire 3/4" thickness at one pass? Can you cut that much plywood or mdf at one pass?
Maybe we should look at a pattern bit.
Mike...
