Why not replace the Nicad CMOS battery. That is what I do. You have to remove it anyway or it will leak and destroy the mother board. It is unsoldered. I use a soldering iron and a solder sucker.
The old bios does not support a HD larger than 504 MB hence the label on the hard drive. If you use a bigger HD you have to Fdisk it for the 504MB and make it a active DOS partition. Then load DOS 6.20 and then the machine software. The CMOS settings for the HD must match per the label. There are many posts here about that.
George
